I’ve had problems with Nito on and off. I had it all set up and running fine for a few months…then a few times, I would go into “Files” - and the mount i had set up did not appear. That cleared up and things were as usual and now again, I had a day of it not showing my mount at all on the “files” screen, then after I reset my computer and may ATV, the mount is back on the screen as labelled before but it will not launch, it just sits there when I click on it. Movies to the same directory work with xmbc so its not anything I don’t think thats changed on my computer.
Any suggestions?
I do have a movie that I think is on the ATV itself and it consistently shows up and runs well from “files” if that helps any.
Thankyou in advance.
