Nito Smart installer problems
Good Day
I have just purchased ATV flash and have installed a couple plug-ins. However I am unable to instal the NitoTV smart installer :frowning: it first tells me that it is going to download the update and they says "an error has occurred. It gives no further information.
I have read somewhere about downloading the 10.4.9 update manually and putting it in the documents folder or something…
One of the main reasons I bought the software was to unlock some of the features available after using the smart installer.
I am sure I have a new connections as I have the codec pack and Mplayer.
Could someone pls pls help.
ā€œMacOSXUpdCombo10.4.9Intel.dmgā€; http://www.apple.com/downloads/macosx/apple/macosx_updates/macosx1049comboupdateintel.html
SSH into the AppleTV and SCP the file to the /Users/frontrow/Documents folder on the AppleTV.
I’m having this issue also. What is SSH and SCP?
Searching those with google just seems to suggest all I have to do is copy the dmg file into the doc folder. Is that correct?
I have downloaded the .dmg file to my desktop. Just need more info…
EDIT: I should also mention that I can’t find the /Users/frontrow/Documents folder on the AppleTV, using Cyberduck.
When connected via Cyberduck the DMG file can be placed into the Documents folder.
Hello, again.
I’ve found a copy of the dmg file in a ā€œDocumentsā€ folder on the Apple TV.
However, this document folder appears to be in a root folder, because I cannot locate any ā€œusersā€ or ā€œfrontrowā€ folders on the Apple TV.
Thoughts?
When connected via FTP you will automatically start in the ā€˜Users/frontrow’ folder. You can connect via SFTP to see the contents of other parts of the system.
Hi again.
I am using Cyberduck to access the Apple TV.
If I do have the proper dmg file in the Documents folder, and I’m getting the error message still, is there something further I need to do? Mount the dmg image perhaps?
That is definitely not normal. What version of aTV Flash (Maintenance → About) and nitoTV (nitoTV → About) are you running?
Hello, again.
It’s running ATV Flash 4.1.5 and Nito 0.9.4 (take three).
And just to be clear, it’s the mplayer component that won’t let me update it. I get the ā€œan error has occurredā€ message…
