Nito not installing:XBMC showing as installed in Maintenence Menu when not
Nito not installing from Maintenece. Wanted to do an install of XBMC from there. XBMC uninstalled as per James instructions, manually through ssh, but shows as installed in Maintenence. Cannot reset to Uninstalled. Wanted to reinstallXBMC to see if the Hulu was working, as recently reported.
Got it all fixed. Bottom line. Did apt-get auto remove with SSH to clean out XBMC. Finally showed as uninstalled. Then I was able to Uninstall Nito ( wonder if open ssh was interfering?) Did a clean install of XBMC via ssh with Cydia version from XBMC forum.  Working. Even have the Hulu add on working, which is what this entire process was about. So, some file was hanging somewhere even after James’ manual delete was done  until I did the apt-get autoremove thing.:) Learned more about terminal and Cyberduck use than ever. Good experience. Thanks. One day I may even be tempted to undo it  all and reload XBMC from Maintenance or Nito as a check.
