Hi, can someone please point me to a newbies guide to setting up infuse on ATV 4? I have searched extensively and cannot find one.
I have recently purchased the ATV 4, and installed the Infuse App. I love the look of it, but cannot get it to work the way I would like. I was previously running Plex through a mac mini connected to a 12TB WD Sentinel server.
I tried to get the Infuse a pop to connect directly to the server but no matter what I tried (auto and manual) it failed to connect. However, as I was previously using plex, I just connected to the plex Media Server and it worked fine. The issue I have is that I can select the “All Movies” folder on my Server, but then the Infuse app just shows all the movies, no sorting by genre. I have organised all my movies (2,500+) into genre folders on my server, but it appears as though infuse does not import the folder structure. I did try importing each folder and used favourites to link to each folder. That worked but it had no fan art etc, and looked very clumsy. I am all about aesthetics unfortunately.
So anyone who can point me in the right direction to get this app up and running would be most appreciated. It looks great if only I can get it to work correctly.
Thanks in advance
