Hi I purchased ATVF over the holidays, in general pleased with it but have 2 issues I cant seem to find an answer for,
My configuration is I have a new 160 GB ATV and a maxter 500Gb ext hard drive. All works fine in the main. However:-
When watching most videos (DVD’s ripped) the ATV plays smoothly (via NitoTV) but every so often there is a freeze frame for a second then it carrried on…is this as it goes from one VOB file to another?? maybe not I dont know but it happens maybe every few minutes, only for a brief second. It occurs on I would say most DVD’s. What can I do to cure?
I can not get the wireless keyboard to work properley with ATVF…I have a usb keyboard, it works fine as its new, some keys seem to work and reduce volume etc, but when I want to use keys to type in web addresses it does nothing…help?
Indeed, Keyboard support (at least for an Adesso keyboard I use) has improved.
I can now type text, (eg into URLs), so that has been restored.
What it doesn’t seem to support (or I just don’t know how to activate it) is general scrolling around a web page or just left/right scrolling. I can scroll up down, using the right hand side of the keypad, in the Finder menu columns or on a web page.
The rest of the keypad doesn’t respond…and I can’t scroll left/right.
