Hi trying to set this up but get the error:
Smart Installer with a 1.0 recovery dmg in ~/Documents will fix this issue’.
What to do? kina new on this…
Most likely you are trying to set up AFP, right?
For that you will need the AppleTV 1.0 SW.
Guide for the install can be found here: http://forum.atvflash.com/viewtopic.php?f=18&t=2629&p=11172#p11098
But there will be some minor limitations due to the latest 3.0.2 release, see this: http://forum.atvflash.com/viewtopic.php?f=2&t=2673
But aside from that, it should work.
By default the AppleTV will attempt to connect via the AFP protocol, however most newer AppleTV units will not support this protocol. The SMB protocol can be used in its place by setting up a ‘Manual Share Point’. We have a guide for setting this up at the link below.
