Network Mount causes ATV to Hang
Updated ATV through maintenance update as I have many times before, starts up ok then through to the welcome display but then hangs after this for ages, then after a while the  apple logo appears then disappears then appears.
Removing the mounts.plis found in the Library/Application Support/nito folder can solve the problem. But its only temporary the moment you reconfigure a mounted or unmounted Volume the problem reappears. Also tried removing Library/Application Support/into and Library/Preferences/com.apple.frontrow.appliance.nitoTV.plist but the moment the Smart installer is run the problem bounces back.
  • Ok here the thing.
    I can eliminate the problem by removing the 'mounts.plist' file.
    Then Re-Boot and re configure any mounted volumes or collections via nito/ network/ mount
and then and only then if I UNCHECK the AUTOMOUNT option. I can remove the problem.
The moment I ask it to auto mount it will hang on start up.
This is where your problem stems from.
I have confirmed this on a backed up Hard Drive.
  • Any thoughts anyone
This issue has been resolved.  The fix can be found here: http://forum.firecore.com/topic/2657
