Network is unavailable on Golden Gate public beta
Hello,
all my apple devices are running on latest public betas and on the MacBook Pro, the infuse can not connect at all to my NAS network drive.
“An error occurred” the only message I got.
On iOS, AppleTv, iPad works just fine. Tried to reinstall or discover the network and reconnect, but nothing.
Any help would be much appreciated.
On your Mac…be sure to include the NAS drive in your login commands
This is not an Infuse issue per se, this currently hits ALL apps on macOS 27. Apple has added some new “security” shenanigans that prevent apps entirely from accessing local network resources. It should trigger a request for permission popup, but it doesn’t.
You can try accessing something locally with your Chrome browser and it won’t work, either. The only app I have found to not be affected by this is Apple’s own Safari.
Such is the price you pay for running betas. They have bugs. Sometimes massive ones, like this one.
This bug is also present in the latest dev beta (beta 4).
Thank you for the reply, I wait then for Apple to fix it. :slight_smile:
