Can anyone help please?
Infuse can be used to point to a folder on my laptop where files are stored to stream on ATV2.
The only trouble with this is that it will only work when my PC is turned on.
If i was to buy a network HD would infuse then be able to point to that to stream from without the PC being on?
This for example
http://www.pcworld.co.uk/gbuk/data-storage/hard-drives/network-hard-drives/wd-my-book-live-network-hard-drive-3tb-black-09520166-pdt.html
Hi.
I have similar setup. In general network device needs to support one of network protocols infuse will understand. From my experience I can see that SMB (Samba, windows) will work. You will find it in Shares, add to library and fetch the content.
I experienced minor issues - loosing host etc. But in general it works quite good.
I bought a Western Digital Mybookworld and it works fine !
The only problem I met is when it doesn’t see the drive (once a year i’ll say) I have to mark my movies and tv shows as seen but with a trackt.tv account, everything is fine now.
