NETFLIX wont connect!!
Using 2nd generation AppleTV. Updated to latest aTV Flash software.
I have a good wifi connection.
Netflix wont connect.. The spinning circle just keeps spinning.
My other appleTV in my bedroom without a jailbreak or aTV Flash works perfectly..
Which version of ATV software are you running?  Netflix have changed their server-side software and it will no longer connect to the Netfilx App on ATV running the 4.4  firmware
i updated my ATV2 to the new un-tethered 5.3 and Netflix again works (although sadly the Plex app is gone - it was much better than infuse.)
I have also updated firmware to the new untethered version.  Still no connection.
same here. cant connect to the Netflix or CrunchyRoll. it started happening i updated to the latest version for aTV.
So i'm running the same software but it says it can't connect to netflix. I'm also having an issue updating XBMC.
Any thoguths?
[quote="davidw.0461"]
 I am staying on 4.4 as it is a much better looking version than the newest firmware. Regrettably my Netflix doesn't work either.
[/quote]
