NAS that is infuse(ATV) compatible AND MacOs compatible (can mount the NAS volumes on macbook pro and read/write to it)
I can’t seem to find a NAS that is both Infuse compatible AND MacOs compatible (can mount the NAS volumes on macbook pro and read/write to it.) I’ve looked at many of the solutions that SEEM to fit (WD MyCloud, Netgear, etc) but in the end, their software either won’t let the Macbook read and write to the drive, or it won’t let Infuse on the Apple TV stream from the volumes. I’ve been using an Apple AirPort Extreme with a USB drive plugged into it, which has worked splendidly. But then the AirPort got old and needed replacing, so finally, after trying out several alternatives, I went back to the AirPort, which is discontinued, so I had to find a used one on Ebay. And that has worked fine, but now it, too, is wearing out. HELP!! Is there nothing out there that will allow me to mount a drive on my WiFi network, mount a volume on my Macbook, copy files to it, and then stream those files from Infuse on the Apple TV? It has been such a sweet setup for years, I can’t imagine giving it up.
18 posts were merged into an existing topic: New with infuse, what NAS should i buy?
