Here are the tags I need to add :
-HD or -720p
-FHD or -1080p
-4K
-Part 1
-Part 2
Since the actual name of the movie is “Harry Potter and the Deathly Hollows - Part 1” and “Harry Potter and the Deathly Hollows - Part 2” what is the better solution to adding the resolution tag to differentiate the files?
For example : “Harry Potter and the Deathly Hollows - Part 1 - 4K” ?
Followed by : “Harry Potter and the Deathly Hollows - Part 1 - 1080p”
And finally : “Harry Potter and the Deathly Hollows - Part 1” w/ no resolution but HD/720p base.
If you actually have multiple resolutions for each you don’t need to add tags, Infuse will detect the resolution on the scan and if you have multiple resolutions it will show an option to select either.
As to the “Part” tag you don’t need that either since “Part 1” and “Part 2” are actually part of the movie title. Infuse will show these as seperate movies.
