My library does not appear on trakt.tv
Hello,
I have installed the new update and activated trakt.tv but my library does not appear on trakt.tv. Only the shows/movies that I have watched appear and the other ones are just not there. Is it a normal behavior?
Thank you in advance for your help!
I think that is by design. The movies you will see in your trakt.tv history are the one you’ve seen. Once you watch a movie or tv show, it will appear on your trakt.tv library. Also, if you mannually add a movie in trakt.tv, that movie will appear as seen on your atv media player. It works both ways now.
Ok, thank you.
