My atv doesn't work more with atv flash
I have some problems with the atv flash. Couse One of them my apple tv doesn't work.
1° Problem: i install Last.fm, i restart finder but i don't see the last.fm menu in the menu of apple tv
2° Problem: i install remote hd. i watch to a video on iphone and i send the video on apple tv....the apple tv restart but doesn't play the video...simply come back to the main menu
3 Problem: i install "SMART INSTALLER" to use external hd or nas with atv but after i restarted the atv i can't use my atv. I don't see nothing, only a black screen..if i move the remote i listen to the atv sounds, and after some min i have the screensaver  but i can't see the menu so i can't do nothing.
Please, help me
hi,
got the same problem… I reset my Apple TV to factory configuration. Reinstall 3.0 apple firmeware… Install again ATV Flash
and then install Smart Installer then Last.fm… and receive a black screen after reboot.
do this twice.
now I use my Apple TV after without ATV Flash and i’m afraid to try a third install.
hi,
do this twice.
But we paid for the ATV Flash so i'd like to use it
Sorry, this issue is related to a recent Last.fm update. While we're working out the issue a quick fix can be found here: http://forum.firecore.com/topic/3633?page=1#comment-12575
Tks for answer.
But with the app that u linked, do i have to remove last.fm from mac or from appletv?
Running that app on your Mac will remove the current version of Last.fm from the AppleTV.
