Hi, I have several webdav shares with the same base address but different path, and when it syncs in iCloud it merges both as one, and the paths are lost.
Instead of having multiple shares for the same device, you may consider adding a single share and creating separate favorites for the sub-folders/drives.
I can’t, they are only accesible via their path, they are different devices, they just share the same url. I tried using symlinks like I said, to merge them, but they don’t work in Infuse (they work in Webdav tho).
I have the same problem. I have multiple disk drives that hold movies. I cant make a single share. I complained about this before via email. When will this ever be resolved? this is so basic stuff…
to resolve I had to use Plex as the media server which supports multiple paths on the same device.
I ran into the same issue today, I thought it was the lagging issue caused by iCloud, I even uninstalled it completely, and it is still not working. Then I found this post, Gotha. Have you found any solutions to it? I could technically just add a single share and create separate favorites for the sub-folders/drives, just like you suggested. But really hope it would be possible to have multiple shares with the same address but different Paths.
