Multiple versions of a TV series
+1. The multi-version feature of the series is very much needed
+1 In my case, it would be really useful for TV series that have a different edit when dubbed.
+1 for smart grouping of tv shows! I’ll buy you a pack of skittles James
I have 1080p and 4k versions of TV series. I want to combine the multiple versions into one and display the episode order normally, such as 1, 2, 3… instead of 1, 1, 2, 2, 3, 3… . Manually select which version you need to see, like a multi-version movie, or select the preferred sharpness.
I don’t want like this:
I moved your post to an already running thread requesting this feature.
This really is becoming more and more important to me as series such as Frasier and Seinfeld are getting Blu-ray or even 4K UHD releases but only in the US while the foreign language versions continue to only be available on DVD. With Seinfeld for example, at least in theory someone could have in their library 4 separate SD versions (due to the different dubbed language editions) plus a Blu-ray and a 4K version. In practice you’d probably aim to combine the SD files into one and skip the Blu-ray but still… that would make my point less dramatic… :smile: In any case I’d just really, really like to be able to store multiple versions of TV episodes…
Hi @james!
Any plans for this?
Since you have implemented this functionality for the movies part, we hope that we will be able to see this one in a short time frame…
Thank you!
