Multi-version naming problem
I created several movies without data in my local folder of my phone for testing
I have checked the naming rules in the infuse manual. Regarding the custom labels that can be used in multiple versions, my naming is shown in the figure. Why is there no merge in infuse? I have opened multiple “multi-version merge” in the settings of infuse
Tags are only visible while browsing via the Library.
I has know
It’s suport multiple-version for tv-show?
Not yet but you can add your support for that feature here.
