Not sure what the best method is of handling DVDs that span multiple discs for Infuse. For example, God Father III is comprised of two DVDs. I currently have all my movies stored on a media center PC using the VOB format. Similarly, I have several other DVDs that use both sides of the DVD, ie., Gone With The Wind has side a and side b. I presently store them as two discs, or sides, in separate folders (eg., Gone With The Wind - Side A and Gone With The Wind - Side B).
Infuse simply drops them in Other and does not pull the metadata for them. So, what’s the best way of handling these DVD files?
