Muddy audio quality in Infuse vs clear on Plex with Apple TV
Hi. I’ve recently subscribed to Infuse as I’ve heard good things about its support for various types of playback on Apple TV.
I’ve noticed there’s a huge degredation in audio quality when playing some files in Infuse compared to Plex. The sounds through Infuse are muffled, have lost their brightness, and are missing what feels like most of the mid-range. Almost like there’s some channels missing? Sorry, I’m not best experienced to articulate the exact issue. I can provide a recording of the differences if needed. Though I’m not sure if the full effect will be captured on my phone’s microphone.
For one of the files in question, in Plex the file source is Direct Play, Video HEVC and Audio EAC3. Infuse reports the audio track as English - Dolby Digital Plus 5.1.
My setup:
  • LG OLED 55" C3 4LA (webOS 8.2.0-710)
  • Apple TV 4K (tvOS 17.3 21K646)
  • LG S60Q (2.1) Soundbar
Apple TV --[HMDI]--> TV --[HDMI eARC]--> Soundbar (Cinema sound profile)
  • Infuse Client 7.7 (4729)
  • Plex Server
  • Plex Client 8.31 (7837)
What I’ve tried:
  • Played file via SMB share in Infuse.
  • Played file via Plex share in Infuse.
  • Changed LFE in Stereo Downmix and Downmix Volume independently and together.
Here’s the MediaInfo for the file being played.
Video
Format : HEVC
Format profile : Main@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 3 h 0 min
Bit rate : 15.0 Mb/s
Width : 3 840 pixels
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.102
Stream size : 18.9 GiB (95%)
Language : English (US)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : 19 ms
Stream size : 994 MiB (5%)
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
