i tried to install mplayer codecs, but there was an error doing so.
I suppose the codec page cannot be found…wrong link ? Internet connection works fine…
how to install the new Apple firmware (2.1) ?
I have 2.02. Better keep it the way it is or doing a firmware update.if so, how can i get update functionality back again?
(Using ATV Flash 3.2
The 3.2 version of aTV Flash is best used with the 2.1 Apple TV software. If you did not disable the auto-update, you can update through the settings menu, then reinstall the aTV Flash.
If you did disable the auto-update, you will need to recreate the flash drive with this option disabled, reinstall the aTV Flash (to re-enable the update feature), update the Apple TV software, then re-install the aTV Flash again.
