Movies not showing synopsis
my movies do not show the introductions only show casts and crews
All movies or a few? Example if only some?
Are you using Plex, Emby, or Jellyfin servers? If not, what protocol are you connecting to your share with?
What version number of Infuse are you using and are you using the pro subscription?
Can you show a screen cap of what you’re seeing?
almost all,the movies is in my nas
And the rest of the answers?
infuse 7.5.5 and pro smb in nas
First thing to try is maybe update Infuse to 7.5.8 which is the most current. Also has it completed the scanning? That can be seen on the library screen.
all done. maybe the problem is that my movies topic is chinese.so I want to know the naming convention
Movies are usually movie name and release year like
Pulp Fiction (1994).mkv
Do you have NFO files present for these videos?
We’ve found certain NFO files will cause issues in Infuse, and this will result in an empty synopsis. This is something we have on our radar to address.
