I am connected via FTP to my appletv.local, and have put a few of my movies into the “Movies” folder (and they show up on AppleTv). I have selected to use the external USB drive as my primary iTunes storage. The problem is that the movies I transferred are not going to the external USB drive (see output below).
Before transfer…
-bash-2.05b$ df -h
Filesystem Size Used Avail Capacity Mounted on
/dev/disk0s3 900M 550M 341M 62% /
devfs 98K 98K 0B 100% /dev
fdesc 1.0K 1.0K 0B 100% /dev
512K 512K 0B 100% /.vol
/dev/disk0s4 36G 5.4G 30G 15% /mnt
/dev/disk1s2 931G 110G 821G 12% /mnt/Scratch/Volumes/MediaHD
After Transfer…
/dev/disk0s4 36G 7.1G 29G 20% /mnt
My first attempt was to add my movies from my local mac attached USB to iTunes (while holding down the option key), such that iTunes would have a reference to the movie but leave the content on my external drive. The problem here is that the .m4v would not sync to AppleTv. This would be my preferred solution.
Anyhow, neither seem to work. How can I get my movies on the external USB?
