Movies in USB drive set as internal
I will soon be attaching my 1.5TB USB HDD to ATV. If I set the HDD to be internal storage…where will the movies appear…under NitoTV or MyMovies…can you make it appear under MyMovies?
thx
Movies that have been synced via iTunes will appear in the same location as they currently do. Non-iTunes media can be accessed through the nitoTV → Files menu.
