Thank you for your reply and advice. I understand that there may be slight differences in the file names of the files.
But my point is that this problem wasn’t a problem with the earlier versions and dare I say neither does Plex with same file names have this issue either. Slightly different dates are usually still recognised correctly.
Example the movie 1917 (2019) shows as year 2020 in the TMDB. Plex recognises it Infuse ipad does not, unless I manually edit the metadata.
Similar but diff with 2 Guns (2013) shows in TMDB as 2013, but not recognised by Infuse ipad. Same with Personnal Shopper 2016.
These were all recognised and organised perfectly before the recent change, so has something changed at TMDB as well as the Infuse update, perhaps in coincidence??
I have run a metadata refresh n the ipad twice recently. Nothing changes.
cheers CD
BTW - Regards the above earlier - Vast of Night is 2020 movie, and Queen of the Ring is 2024.
As mentioned above, it would be best to use the primary release year as listed on TMDB. As of 8.4, this is what Infuse will use for matching movies and TV shows.
I’ll be adjusting them all with the tmdbid… With Filebot this is reasonably simple, just check that Filebot fine the correct show/movie first. Otherwise the tmdbid is in the url of the web page.
Question about the adding of the TMDBID. Does it also work with TV shows and folder names?
I mean it’s easier to add {tmdb-xxxxx} to a folder than to every single episode released. Just think of The Simpsons with 37 seasons of some 25 episodes…
Just a thought, if you’re using a Mac then it’d only take a minute to rename all of the series folder. The “Rename” function with “Find and Replace” works great, and fast. Just select all of the files and rename them.
Also to the Walking with Dinosaurs series, adding the year to files and series folder also works very well.
The idea I had was, because the year is mutable, to simply have
Walking with Dinosaurs {tmdb-xxxx}
After all, the id is immutable, so they could rename it to “Fred Flintstone’s favorite pets” and change the year to 25.000 BC it would still go to the original one I wanted. In theory the folder could be named {tmdb-xxx} and it should suffice.
[edit]I use Filebot as a batch rename tool, and simply used {Plex} as rename mask. I was surprised the dinosaurs were linked to the 2025 version[/edit]
I’ve never tried adding the TMDB to the folder but if it works that’d be great.
If it doesn’t work it’d make a good suggestion for Infuse.
I’m stuck in the Apple/Mac world so I stick with the old reliable rename built into the finder but I may give Filebot a shot if they have a mac version.
The Mac rename would work to put the TMDB numbers in the file names too just as fast if a user doesn’t have access to filebot.
So, I have this documentary series named Kingdom.. I threw it through Filebot formatting the file so it ended in the {tmdb-xxxxx}.
Infuse does its scanning game, and to my surprise it is recognized as an animation thing also called Kingdom. This one is from 2012, instead of 2025 which is the year of the documentary…
So, ehh… TMDB adding is not registered? Ignored?
I rename the directory it’s in to Kingdom (2025) and scan… “Wrong bet, Hans!”
I use a renaming tool in Finder to add “(2025)” after Kingdom and scan… Yaay! Finally!
So, what is the deal with that TMDB suffix? It only works for movies? Why? You already have the code… It’s not difficult to add that to the episodes metadata hunting game, instead of this half assed approach!..
Couple of things, first this is a TV series not a movie so that make it a bit more effort to get the right metadata.
TMDB and IMDB ID numbers only work for movies currently. You can add your support to a currently running suggestion thread requesting this feature for TV shows.
You’ll have to stick with adding the year to the file names for the six episodes and main series folder to get Infuse to pull the correct metadata.
I’m going to guess it’s not as simple as duplicating the code. For a movie you only have to scan one item for the ID where as with TV shows it could be thousands of episodes that have to be checked for ID numbers.
At least it’s easier than it used to be to match TV shows now that the Year in the file name is taken into account.
I also have the same problem. For me the date we put in the metadata should always be the date when the movie was released in the country of origin. I appreciate that Infuse cannot understand what is the country of origin of the movie until it has identified which movie it is but there must be away to workaround this by code so we would not need to change our metadata. For instance if we chose “use original language for metadata”, then see if there is a match with the first release date of the movie
