Hello, on few films there is no movie poster show in Infuse, but they are available on themoviedb.org
I can’t figure out, do you have an idea ? Thank you
Here are two examples:
Please try disabling the ‘Embedded Metadata’ option found in Infuse > Settings, and then use the Edit option on the affected videos to refresh the artwork.
It worked perfectly, thank you very much ![]()
