Movie names appended with “director cut” etc
Movies like this requires manual metadata updating
If you put the version like “Directors Cut” after the year it will work without manually updating.
You have to have the movie name first, then the year, then after the year you can have what ever you like such as directors cut, IMAX, Black and White, edited, unrated, etc.
Some times, the naming is not up to me, and I can’t rename it without making a copy. If you know what I mean.
It would most likely require TMDB to re-write their API to support additional search modes and I doubt very much it that’s going to happen.
Not sure why you can’t just rename a file but that’s the clean and fast solution. Otherwise, you’re going to have to go the edit metadata route.
because renaming a file will change its hash
