Movie metadata won't load correctly under 4.2 final
After testing 4.2 RC without any problem, the final version of Infuse 4.2 won’t load the metadata of Movies correctly. The fetching progress seems to start over and over again.
When I disable the folder witch contains movies and only leave the ones with tv-shows active everything works fine.
I’m streaming the content over smb from my Synology NAS running DSM 6.0
The Apple TV runs tvOS 9.2.1
I hope someone can help me
Regards pat
There may have been a TMDb server issue over the weekend.
Can you see if everything is working now?
I could have thought of that..
Now everything works fine.
Thanks for the quick response and keep up the great work :slight_smile:
