I tried a lot of things until I found out he wasn’t at http://www.themoviedb.org/ is listed.
With IMDB, however, it is. Is there a way to add the movie manually that it appears under Movies.
Now it appears under “other”.
In this case, you can add your own metadata and artwork manually using XML and JPG/PNG files. This will allow the movie to appear in the correct section.
More info on the options for doing this can be found here.
