Movie Details page not formatted correctly on ultrawide monitor
On a 49" ultrawide with a resolution of 5120x1440, on the movie details page the format if wrong. The Movie poster is two screens tall and then the details are under that so all you see is the top half of the movie poster and nothing else until you scroll. Has anyone else seen this? Is there a workaround?
You might want to try using a fanart pic that is formatted for the wide screen. I don’t know if Infuse would use that different size or even how it would interpret it but it’d be worth a shot.
I don’t have answers, but it might help to know whether you are referring specifically to Infuse instances installed on MacOS or on tvOS.
  • Edit: Nevermind. I see you’ve posted in the Mac forum. My bad. :grimacing:
