Artworks for movies and tv shows will randomly disappear and reappear after opened Infuse. Some artworks will even do this frequently.
The issue happens in current versions, and former versions as well.
If you’re talking about the poster on some after scrolling them into view flashing and updating in just a second then that’s normal I believe. That’s Infuse updating the artwork. After it flashes once it should stay for that particular movie.
No, the issue is about those flashing multiple times and from what I experienced, there’s no end to this.
