Does Motion Smoothing, as Tom Cruise mentioned in his tweet, have any impact on playing videos with Infuse?
Infuse itself doesn’t add any motion smoothing, so if you disable the motion smoothing features of your TV you will be able to enjoy films how they were meant to be viewed.
In the old days motion features did have some value, as the Apple TV was fixed to 60Hz output, and 24p content would appear choppy. Depending on your TV, some motion features allowed the 24p signal to be extracted from the 60hz stream, or in other cases these features were able to simply mask the minor judder that would appear. Now, since the ATV supports native 24Hz output, we recommend disabling all motion features (as long as you TV supports 24p input).
