Any way or plans to get more settings?
The only thing i like more with mrmc is the subtitle-look
You really need to be a bit more specific, what kind of settings options do you want? There are several options currently that you may not have found yet and we could help point you in the right direction.
What specifically about the “subtitle-look” of mrmc do you like?
On second thought i think its fine. More customization for subtitles i guess
Well if you think of a specific change or option you’d like to see please feel free to start a thread in the Suggestions sub forum here https://firecore.com/forum/suggestions so other can share their support for your idea!
Its the hands down best app ive used so ? i just did a new thread about occasional lags tho, not sure what the problem is, might not be infuse
