More appearence options subtitles
So infuse is almost perfect ?
I wish for more options concerning appearence of subtitles.
Such as thicker outline option. Mrmc/madvr/kodi etc have this, its good cause then u can use Grey as color instead of bright white and still see text well. lets implement it :slight_smile:
Just for future reference, there is a sub forum dedicated to suggestions and requests here https://firecore.com/forum/suggestions
Also there is a search bar at the top of each forum. If you browse through the Suggestions forum I believe you’ll find a couple of currently running threads you can add your support to for changes to subtitles.
Here’s one for example Add background behind subtitles
Sorry and thank you.
