MKV scrubbing issue
Hi, I have this MKV video, quite a large one, 32 GB. It plays fine except I cannot scrub (jump to where I want to watch). Every time I try to jump forward (say from 00:00:00 jump to 01:00:00 ) it tries to load for a minute but it only moves few seconds forward (from 00:00:00 to 00:00:30). The file has chapters but it doesnt do anything either.
The video plays and can fast forward just fine in PC. But not with infuse both TvOS and IOS version. I just wanted to know if this is the current software limit or something wrong with my settings? Thank you
Below is the video spec:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 3 h 20 min
Bit rate : 13.2 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.212
Stream size : 18.5 GiB (56%)
Title : MPEG-4 x264@High Profile L4.1, 30/1.001 fps @ 13200 kbps
Writing library : x264 core 148 r2665 a01e339
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=13200 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=45000 / vbv_bufsize=45000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:0.60
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Bit rate mode : Variable / Constant
Bit rate : 7 383 kb/s / 1 509 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 96.0 kHz / 48.0 kHz
Frame rate : 93.750 FPS (512 spf)
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Stream size : 10.3 GiB (32%)
Title : Chinese DTS-HD Master Audio 5.1 (96 kHz / 7486 kbps / 24-bit)
Language : Chinese
Default : Yes
Forced : No
Is this happening with all your videos, or just this one?
Hi James, just this video have this issue. I have tested another 8GB mkv video jumps straight to where I wanted within a second
