Mkv and Mpeg2
when I play mkv movie, it’s lagging, I convert it with makemkv, and all my movie do the same thing
I just tried with mpeg2 as well, do the same thing, lag !
what can do this ? I got a network drive so it is connect by cable to the rooter, this is suposed to go fast.
See my post regarding this issue, I am having the same problems. It is not the file format or type, it is the amount of data coming down the pipe.
I am sure they can fix, if Apple can stream 720p with AC3 with the internet and wirelessly. it is just a matter of playing the the transcoding and the buffer cache size.
I have posted all the files and reports for them to troubleshoot the problem. I will post again, once I get an answer.
