Missing movies in media player library
I realize that many threads have been posted on this particular issue, but scouting through the forums I am yet to find the issue of missing movies resolved.
I have successfully added two shares to my library: a folder containing tv-shows and a folder containing movies, both located on an external hard drive.
In the Library Settings menu, the Media Player can find 135 movies (which corresponds to my actual number of movies on the hard drive), but when opening the library, only about 70 of those are shown (according to a quick count). If I use the search function or enter my shares via the My Files menu, I can easily find the missing movies, and if I re-fetch the metadata for each of the missing movies, they’ll show up in the library (ruling out the ‘wrong filetype’-question), but obviously this is far from ideal, considering I’d have to do this for about 60 movies.
Does anyone have any ideas on how to solve this issue?
Thanks in advance,
Martin
I am also having the same problem!
What i have found that my movies which have 2 parts are missing
Hope someone can help there too
Thanks also
P78
