Missing artwork on Media Shelf
Cover art for some movies has gone missing from the Media Shelf. The artwork shows up in Infuse, but the item on the media shelf shows a thumbnail from the video instead of the cover art. This does not happen with everything, so far it's only been a couple of movies.
I've tried clearing my metadata and getting it all again. I've tried reloading the metadata for the specific movies. I've tried uninstalling and reinstalling Infuse. The only thing I have left to try is wiping my ATV and reinstalling everything from scratch. I'm sure this will fix it, at least temporarily. But I have a feeling the issue will return with time. I haven't done this yet, because it's a bit of a hassle.
Anyone else seeing this?
This is related to a recent change at TMDb.
We've worked with them to get a workaround in place that allows the current version to work as expected.
An update with a more permanent fix will be available soon.
Thanks for your patience.
