Both the Infuse for Aptv and the Iphone are presenting Metada in portuguese of portugal even configured for portuguese of brazil.
The films download the correct cover, but the title and the information is in Portuguese of Portugal!
And there are some differences of Lingaguem between Portuguese from Brazil and Portugal.
Can you correct ?!
I love the program, and that’s just missing it for it to be 100% perfect for me!
Thank you
Sorry, my english from google translator.
Below is an example:
Monstros Fantásticos e onde Encontra-los (Portugal)
Animais Fantásticos e Onde Habitam (Brazil)
5.4 is currently under active development, and we’re hoping to have it available soon.
With regard to French metadata, Infuse will attempt to fetch details for all your videos in French - however, in cases where French metadata is not available on TMDb/TheTVDb for a particular title then Infuse will fallback to English.
I updated a few minutes ago but it makes no difference. (This issue also happens on Apple TV.)
This problem happens with every TV show. It ignores pt-BR metadata and only sees pt-PT. Since there is no region differentiation for the images, they work perfectly.
Take “Batman - The Animated Series” as an example. There is no metadata with the name of the episodes and synopsis in pt-PT, but this information is complete in PT-BR.
I deliberately inserted only the title of E01S01 in the pt-PT metadata on TMDB site and bang! This is the only information InFuse has downloaded in my pt-BR app.
Now the only problem is that Infuse is reading the metadata in Portuguese from Portugal (PT-PT), instead of Brazilian Portuguese (PT-BR) as I selected. I had already warned about this bug more than 1 year ago but it seems that it has not yet been resolved.
I will not be able to test, because I do not have a subscription to Infuse, but I am happy to know that they solve the problem. It is a very good product and deserves to work correctly with Brazilian Portuguese.
Hi and thanks for what has been be a long awaited solution. I have however experienced an issue.
My app displays in Spanish (Mac, Apple TV and iPad’s) as I live in Spain , I have audio and subtitles set to auto. My Library is in Spanish(Spain) and English, however I have Just changed the metadata setting to “Original” and requested a metadata update. After the update a Lot of the English series and films are showing in Spanish. The strange thing is that when i go to change an individual files metadata, it actually states metadata language “English” in the metadata Edit window and provides me with the English metadata to select. The Problem seems to be that it is not applying the correct Language in an automatic metadata update of the entire library.
Would really appreciate your feedback in case I am doing something wrong.
Hello James, the metadata was working as you said, when we where choosing the French metadata, and the french text was not available, it was falling back to English metadata. But it seems this functionality desapeared with the 7.5.3 release. At least with tv shows ( like tv show : the ark)
In this case ; no metadata appears at all.
