MetaData TV Shows 'The Flash' 1990 and 2014
Folder Structure
The Flash (2014)
Season 1
The Flash (1990)
Season 1
When I change the MetaData online to match per series, its marking all as either 1990 or 2014. These need to be separated by series. What is the problem? When I use Emby or Plex, it matches each series correctly.
How do you have the individual files for each named?
Hi Thanks for the reply, directory structure / episode naming is below, only 1 example is listed per series but all episodes follow the same naming format.
The Flash (2014)
Season 1
The Flash S01e01 City Of Heroes.mkv
The Flash (1990)
Season 1
The Flash S01e01 Pilot.avi
If you add the year to the file name like the folder it will pull the correct info for both.
The Flash (2014) S01e01 City Of Heroes.mkv
The Flash (1990) S01e01 Pilot.avi
I’ll try that and report back, thanks.
That worked, thanks!
