Right now I’m very happy with version 5 Pro.
But for ONE thing, the metadata which are supposed tobe saved in icloud and just never worked!
It saves nothing and I’m getting quite frustrated having to correct it every once in a while!
Is it FINALLY working as promised in version 6?
Besides your pricing scheme makes no sense for this type of product, you can afford it because you have no competitor on the field, but you are frustrating your customers.
Hello?? Is there anybody in charge of marketing?
(Your product is awasome though…)
Infuse 6 includes an all-new iCloud integration, which is a dramatic improvement over v5. Not only is it more robust, it’s much faster and syncs complete libraries, so you always have a backup in the cloud for things like watched statuses and metadata.
The most straightforward way to upgrade to Pro is one of the subscription options available through the free Infuse app. These are low cost, and ensure you always have access to the latest and greatest features.
If you want to take it for a spin, you can download the free Infuse 6 app and start a yearly subscription for Pro. This will allow you to play with everything for 30 days for free.
