Can anyone help me please?.I am going round and round in circles.I have 2 tv shows, with the same name, "the Incredible Hulk (1977 live action series), also "The Incredible Hulk (1996 cartoon), I can’t get Infuse to show the correct data for each show, these are both correctly named, they have different TMDB #, but when I change the metadata for one, it affects the other.Thanks
Include the year in both the folder names and media file names.
The Incredible Hulk (1977)
Season 1
The Incredible Hulk (1977) S01E01.mkv
The Incredible Hulk (1996)
Season 1
The Incredible Hulk (1996) S01E01.mkv
It also helps to keep each series in its own folder, as Infuse will generally assume if you edit the series identification of an episode in a folder, you want to apply that edit to all episodes in the folder — thereby saving you the need to edit every title individually.
Thank you, that worked perfectly
