Metadata picture choices from thetvdb.com
Hello,
The issue I’m having right now is that I’m watching season 19 of Doctor Who ( http://thetvdb.com/?tab=season&seriesid=76107&seasonid=9676&lid=7 ) and Infuse loads the metadata using the second image from the right side of the webpage. This image in my opinion is of a lower quality than the one above it and it also misspells the lead actor’s name. Is there any way I can get Infuse to change the image it is using for the season without having to put everything in folders and manually download the image by myself?
Infuse doesn’t have a way to select which poster to use (at least right now), and will always use the top rated image.
What you can do now is sign up for a free TVDb account and submit rating for various artwork. This can often times lead to quick results with switching which items appear as top rated.
