Metadata Not Working Correctly
I have a weird problem with a TV series, Beavis and Butt-head (1996). The file names are correct; they match the data on tvdb.com and the metadata selector finds the show correctly. However, Infuse fails to load the correct data and shows the show’s metadata for every single episode. I’m not sure what is wrong, I’ve never seen this behaviour before.
Does anyone have any suggestions?
File Structure is,
TV Shows / Beavis & Butt-Head / Beavis & Butt-Head S00E00 - Title
First, Infuse no longer uses TVDB for TV shows, it now uses TMDB for both TV and Movies.
I would suggest using “Beavis and Butt head S01E01 Title.mkv” instead of using the ampersand, that symbol can cause problems with metadata.
I would use this for both the file structure and the file and folder names.
That was it. TVDB lists it as S09 and TMDB lists it as S08. Renamed and all good. Thank you!
