The show is called Mr.Robot (2015) but its not listed!
I’m guessing it’s due to your file name. The season and episode numbering is a bit off.
Try naming the file
Mr Robot S01E09.mkv
When you have S01 then a dash then EP then a period then the 09 it’s not using the correct format for season/episode numbering and then Infuse thinks it a movie.
I can’t rename. Im using RD via WebDAV. Is there any other solution?
Why not integrate a show/movie option that we can choose while searching metadata? Or enter IMDBID or TMDBID to get the exact match?
I think that’s the only way for now.
You can add your support to a currently running suggestion requesting the ability to search both TV shows and Movies for metadata.
