Hi all!
Infuse pro latest ver. from appstore + Apple TV 4K.
A few TB TV shows library from SMB share. All tv shows metadata is ok, except “Rick and Morty” and “Twin Peaks”.
Infuse pro can not recognize and download metadata for Twin Peaks Season 1 and 2. Season 3 is ok. Rick and Morty - all 3 seasons
The folders structure is: d:/TV Shows/Rick and Morty/Season 1/Rick and Morty S01E01.mkv
The same with Twin Peaks.
I tried different file names, according this page Metadata 101 – Firecore but it’s doesn’t help. Also tried different language for metadata settings.
Any ideas?
Welcome to the forum! Sorry you’re having issues with those files. I just tried both using the folder names you provided and both worked without a hitch for me.
My metadata is set for “English (United States)”
Both series grabbed the artwork and synopsis as soon as I opened the season folder.
Have you tried long pressing on one of the episodes that doesn’t have it’s metadata and done the edit metadata search?
