Metadata Miller's crossing
I have a movie named “Coen brothers - Millers crossing”, so naturally Infuse can’t find it. However when I edit the title manually I can’t get it to find Miller’s crossing at all. Also if I only search for “miller” to avoid the special character, it can’t find it.
It exists at themoviedb, but I don’t know if that’s the title source.
Can anyone else see this movie in the search results?
I assume you mean you changed the name to “Miller’s Crossing” or even “Millers Crossing”. If it’s not getting that then perhaps Infuse is not set to scrub this location as “movies” and may be trying to see it as “TV”. Not sure if there’s a way to set this like you could in Infuse for flash black.
