Metadata lookup bug, 2.2 and 2.3
When looking for a movie with filename "13 (2010).avi", the metadata lookup finds "District 13: Ultimatum".
The FAQ tells me that you use TheMovieDB for lookups, yet the first result when querying there returns the correct result:
http://www.themoviedb.org/search?query=13
(this is the correct result: 13)
Curiously, "District 13: Ultimatum" doesn't actually feature until page 2 of the results. Is this a sorting issue? It seems to return result 11 instead of result 1... might just be coincidence though.
I'm slowly working my way through a huge library of files, so I'll post here if I spot any other oddities.
Another:
Movie file named "10 Items Or Less (2006).avi", returns "X-Men: The Last Stand".
http://www.themoviedb.org/search?query=10+items+or+less returns the correct result though.
I'm also surprised to find that adding a release year ("2010" in the above example) doesn't affect the results. How should files be named in order to ensure the correct release of a movie is returned?
EDIT: It seems adding the release year does work - just not when the incorrect results are returned as above.
(So for example, the system IS able to discern between "Taxi (2004)", "Taxi 2 (2000)" and "Taxi (1998)"
And Another:
"The World's End", returns "Pirates of the Caribbean: At World's End".
But this returns the correct result: http://www.themoviedb.org/search?query=The+World%27s+End
I'm going to stop now, as I'm finding too many errors, and my file names (whether they include a release year or not) don't appear to be at fault.
Any help appreciated.
EDIT: does the scraper ignore "The" ?
Another:
"Enduring Love (2004)" returns "Love's Enduring Promise (2004)".
http://www.themoviedb.org/search?query=enduring+love
Hmm, we'll take a look at these and see if we can track down what might be going on.
In the meantime, you should be able to correct these manually by following the steps found here.
http://support.firecore.com/entries/23704917-Metadata-101
Thanks. I'm aware metadata can be tweaked, but it's not a practical solution for the number of issues we're facing (and across 3x iOS devices).
It's also difficult to spot where a movie has been mis-categorised when your movie catalogue extends into the hundreds... I've taken to importing them in groups of 20, so I can double check them as they're scraped, but it's pretty slow progress.
I've just put the problem movies into a holding pen until I hear back from you :)
Another:
"Legacy (2010)" returns "TRON: Legacy".
...which is actually result 17:
http://www.themoviedb.org/search/movie?query=legacy&page=2
[quote="avidmoviegoer"]
[/quote]
Cheers - we'll see what we can do. :)
OK, here's the complete list of movies I'm having trouble with (actually a very small percentage of the total, which is good):
  • 10 Items or Less (2006).avi
  • 13 (2010).avi
  • Il Futuro (2013).mkv
  • Legacy (2010).avi
  • The Ex (2006).avi
  • The World's End (2013).mkv
In all the above cases, the file is contained in an identically named folder (minus the file extension of course).
Finally, I *believe*, InFuse attempts to use the folder name where the file name is no use (at least, that's what I've observed). I have a large offline DVD collection which I create folders for in order to have them presented in the same list as my online movies. The folder structure for those is like this:
/Movie Name (release year)/DVD-123.avi
...where DVD-123 relates to a slot in my giant DVD rolodex. InFuse has happily imported and correctly indexed around 400 folders named like the above, but struggles with this one:
  • Enduring Love (2004)/DVD-304.avi
That's it - not bad considering there are several hundred titles to deal with, but it would be great to have these resolved.
Many thanks in advance.
Thanks again for the info.
We've made a few small changes in the matching logic that should improve matching accuracy in most cases. These changes will be available in the next version of Infuse.
[quote="james"]
[/quote]
That's great, thanks.
Do you have a published roadmap somewhere? If not, publishing one would surely reduce the frequency with which you have to answer "when will we see feature x" type questions ;)
Also, it might help to expand on the metadata 101 page by including details of how you process filenames (and when you fall back to processing folder names instead)?
Many thanks for a great product.
[quote=james]
[/quote]
[/quote]
No public roadmap yet, but we'll likely get one put toghether once over the next few weeks.
PS - A minor update (2.3.1) was submitted to the App Store today that includes a few fixes, including better title matching. :)
Just a heads up, the 2.3.1 update was approved last night. Give this version a try as hopefully it should handle your probelmatic titles a bit better.
I just downloaded 2.3.1 for my iphone 5s.  I cleared out the metadata cache so Infuse can reload all the cover art.  Unfortunately, I have to report that the metadata scraping is even worst.  Cover art that was found before is not now.  Incorrect pictures(not cover art) are being used and covert art just not being found.
Here is a link to a screen shot of one of my movie directories in Infuse 2.
[IMG]http://i.imgur.com/rGlDq7F.png?1[/IMG]
http://imgur.com/rGlDq7F
The five movies that the cover art is suppose to represent are:
Alan Partridge Alpha Papa  (This one probably just doesn't exist in the database)
Jack Ryan Shawdow Recruit
Lone Survivor
Never Let Me Go
RoboCop
All of my other folders look like this also.  Previous version of Infuse worked fine (expect for the last 2 versions).
Please let me know if I can contribute in helping to fix this bug!
thanks
[quote="mrfatboy"]
Lone Survivor
Never Let Me Go
RoboCop
thanks
[/quote]
Can you confirm the Metadata Fetching option is enabled in the Infuse Settings menu?
Metadata Fetching is ON in the menu settings.
I also just found this link to 'edit metadata'.  I didn't know it was there :(
I actually went into another movie folder and tried to 'edit metadata'.  It worked. It listed the correct movie and I selected it.  I'm not sure why it didn't correctly in the first place.
Now for the strange part,  I went back into the movie folder (pictured above) to fix all that meta data.  When I opened the folder all the cover art was correct.  No need to edit the metadata.  There still must be a nasty bug that is lingering around with correctly refeshing the metadata since 2.3.
As I am trying to cleanup all my movie folders with bad cover art I can definitely say Infuse 2.3.1 is choking on the downloads.  It seems to just stall out when searching.  Multiple fetches must be made.  However, bad data is still coming in.
In regards to the "edit metadata" button.  I see now why I didn't see it in the first place.  It does not always show up as you can see from the below pic.  However, after a minute or so, the background did change (blur out) and display the 'edit meta data".
http://imgur.com/WBEJGU9
[IMG]http://i.imgur.com/WBEJGU9.png[/IMG]
Sorry for all the posts but I'm trying to give you as much info as I can.  :)
I can now tell you that 'edit metadata' does not always work.  If you do select 'edit meta data' and it finds the correct movie and displays the fan art in the movie meta data section the Cover Art is not always displayed if at all.  I had to quit the app and go back into that folder to have it display properly.
[quote="mrfatboy"]
[/quote]
Can you try removing the app, and re-installing it...just to make sure all the old meta info is wiped out?
This normally isn't required, but what you're describing is very different than what we're seeing here, and based on the recent scenario of broken metadata for a few days it may just be best to start fresh.
