Hello,
I would like to know if it would be possible to select a different language for the metadata per folder. I have a share for French movies and another share for American movies. My default language is American English and the metadata for the French movies folder look stupid and ugly in English. Would there be a way to change that? If not do you plan to add that possibility in the future?
This isn’t available at this time, but you may try the steps below as a workaround.
- Select the language most of your files are in and allow Infuse to complete it’s scan.
- Change the Metadata language to your second language (French).
- Locate the videos you with to have French metadata for and use the Edit option to refresh metadata for these videos only.
Alternate step 3 - Long-press on the folder you wish to have French appear for, and select the ‘Use Local Metadata’ option. Then, quickly do this again and select ‘Use Online Metadata’. This will have the effect of clearing all metadata for these videos, forcing Infuse to refresh metadata for them.
James, any plan to have this option in the upcoming version?
No immediate plans for this right now, but it looks like there is a thread in the suggestions area which you may consider following/supporting.
