Metadata Issue
I’m having an issue with metadata on both my Apple TV and my iPhone.
Whenever i edit the Metadata to say Game of Thrones is in the Game of Thrones folder it update correctly.
When i then for example go into the American Horror Story folder it has updated as Game of Thrones. If I change the metadata to say AHS and go back to the GOT folder GOT has changed into AHS.
I’m really confused, can someone help me understand what is going on and how i can fix this.
my folder structure is setup as follows;
/TV Shows/The Big Bang Theory
Season 1
Files
Season 2
Files
Season 3
Files
TV Shows/The Office
Season 1
Files
Season 2
Files
Season 3
Files
…any help at all?
In your examples above, where you say ‘Files’ what do your file names look like? Are they of the form, for example ‘The Big Bang Theory S01E01.mkv’ or are they just ‘S01E01.mkv’?
