I just acquired infuse pro on my TV call and I have a quick question about indexation.
When I’m on my show files, some have jackets with all the summaries and some don’t, I just have a gray incone.
It seems that indexation is not being done. But the name is well written.
Would you be why?
Yes of course ,
for exemple : i have 4 animation series.
Tower of god for exemple, the file is grey and i have no description (i should mention that i go to favorites and completed on infiuse)
But Tokyo revengers : the file is grey, thera are two seasons, but when i enter the file, however each season at its cover (image)
I have a serie with 1 season without dexription and pictures and others with.
If you want to keep things organized in folders by season, it’s best to use a structure like this (as described in the guide linked above).
TV Shows/The Big Bang Theory
> Season 1
> Files
> Season 2
> Files
> Season 3
> Files
TV Shows/The Office
> Season 1
> Files
> Season 2
> Files
> Season 3
> Files
To clarify a bit, do you have tokyo revengers TV series or are you talking about tokyo revengers movies?
There is only 1 season for the tokyo revengers series but there are 4 movies in the tokyo revengers group and depending on which you’re trying to display will determine how the files need to be named and organized.
Edit to add, you can see both the TV series and the 4 movies here and determine how to name your files.
